Is it possible to create a list attribute for specific content of a JSON (in a single transformer)?
thijsknapen
Forum|alt.badge.img+10
Suppose you have some kind of JSON as follows:
   "students" : [
         "id" : "01",
         "name" : "Tom",
         "lastname" : "Price",
         "hobbys" : "football""hockey" ]
         "id" : "02",
         "name" : "Nick",
         "lastname" : "Thameson",
         "hobbys" : "reading""gardening""painting" ]
and I would like to create a list attribute for only some specific content of the JSON. For example, lets say your only interested in only the name and lastname of the students. Then I would like to achieve a result like:
students{0}.name = Tom
students{0}.lastname = Price
students{1}.name = Nick
students{1}.lastname = Thameson
Is there some easy way to achieve that?
I am aware of the following transformers that can extract JSON data:
  1. JSONExtractor
  2. JSONFlattener
  3. JSONFragmenter
However, for the JSONExtractor I'm only familiar with the possibility to create attributes for (single) JSON objects or a specific JSON array element. Is there maybe some option in the JSONExtractor that I'm unaware of in which you can set list attributes for (specific elements of) a JSON array?
Using the JSONFlattener I find myself that the entire JSON is being flattened, so then I always find myself first using a JSONExtractor to extract specific content to flatten, exposing the (expected) flattened attributes, and removing all other undesired attributes using AttributeKeepers, -Removers or -Managers.
Somewhat similarly using an AttributeFragmenter I find myself fragmenting the JSON array of interest into individual features for each element of the JSON array, extracting the desired JSON attributes, and then building the desired list.
I guess there are probably some options to achieve my goal using JSONiq (a kind of xQuery for JSON instead of XML) in an XMLXQueryExtractor transformer, but unfortunately I only vaguely know about JSONiq (basically that it exists and looks like xQuery), and have only limited experience with xQuery for XML.
Although I would be really interested to learn the possibilities of JSONiq for this purpose (maybe someone can share an example), where possible I would prefer to use 'non scripting' transformers to achieve my task.
But then again I'm afraid that using 'conventional transformers' would require multiple steps, and in that case I would still prefer a direct solution in JSONiq.
Curious to hear if others have some experience/ideas on this front.
Kind regards,
Thijs
jovitaatsafe
Forum|alt.badge.img+11
Hi @thijsknapen​,
Thanks for your question! I got some suggestions from the team and it sounds like this isn't possible to do in just a single transformer. One of the best ways to go about it is as you've already mentioned using a JSONFlattener to get attributes, and then removing the unwanted attributes.
Some other suggestions from the team were to:
  • look into using the JSONFragmenter if what you need to flatten needs to generate multiple features. It gives you more control with JSON Query and fragmentation. This also gives you a separate feature per student object (creates a new feature per student object and the object into attributes)
  • OR use the JSONUpdater to remove the unwanted keys before using a JSONFlattener
  • when you've chosen your workflow, you could then wrap up the process as a custom transformer and reuse it as a single transformer
Hopefully that helps provide some more ideas!
thijsknapen
  • August 17, 2021
Hi @jovitaatsafe​ ,
Thanks for the reply. I had another look at it myself, and I managed to make it work in a single transformer using JSONiq inside of an XMLXQueryExtractor transformer, using the following expression:
let $json_doc := fme:get-json-attribute("json_example")
let $students := jn:members($json_doc("students"))
return (
    fme:set-list-attribute("students{}.name"$students("name")),
    fme:set-list-attribute("students{}.lastname"$students("lastname"))
store_json_array_in_list_attributeThis solution was inspired on the reaction of takashi at this question (especially the count distinct elements expression): https://community.safe.com/s/question/0D54Q000080hL8C/count-elements-in-json-array.
Furthermore I found some helpful documentation in the following links:
http://cf.zorba-xquery.com.s3.amazonaws.com/doc/zorba-2.7.0/zorba/html/JSONforXQuery.html
https://nbviewer.jupyter.org/github/ghislainfourny/jsoniq-tutorial/blob/master/JSONiq-tutorial.ipynb
