I'm looking to build a workspace for an FME Server App to read a generated QR code that has a CSV list of attribute values in as an attribute and further transform it. Does anyone have any experience?
Reading a QR Code with FME Transformer (FME Server App)
Best answer by drc43
Hi @runneals ,
I've been playing around with the Barcode/QR code reader in the FME Data Express app lately. You basically set up your parameter as a text field, and then in the app you tap the three dots and it gives you the option to use the Bar / QR code input method. I've found that this works really well, however I don't believe the same functionality exists if you access your app through a browser window.
As mentioned, the field is a text field, so what ever data your QR code represents (a number, text, or hyperlink), that value will be returned in the text field as simple text. I anticipate this working well for reading in a primary key to query or join to another dataset, but it really depends on what your QR code represents and how you'll use it in your workspace. I'd be interested to hear how your app turns out.
