I have two layers: Boundary and Landuse that are living in CAD file.
1. The Boundary layer contains only one hatch object. This hatch is converted to polygon (area) successfully.
2. The Landuse layer contain multiple hatches (299). These hatches are converted to polygons (areas) successfully.
3. Now, I need to derive the roads by subtracting the landuse from the boundary. I was advised to use the “clipper” tool to do so (which is equivalent to the erase tool in the ArcGIS). The issue here is that the clipper tools fails to generate the roads from the Boundary polygon and Landuse polygons.
What might be the issue here?
The source CAD file and the workbench can be downloaded from the links below:
http://www.mediafire.com/download/award80hlujz76z/Tamoun_Tubas_UrbanMasterPlan_02.dwg
http://www.mediafire.com/view/dn9mey2e0ncll66/Roads.fmw
Thank you
Best
Jamal
