Nearest Label to Line DWG Viewport
deanhowell
Forum|alt.badge.img+23
Hello,
I have a DWG file that has it lines in model space but the labels have been added to the drawing in paperspace in a viewport.
I am trying to figure out the best way to validate that the length of the line in model space is the same length as the label in paperspace.
Is this possible?
I have attached a very simple test that I am trying but it is not reading from the viewport.
Be the first to reply!
