Remove multiple underscores that separates words
Forum|alt.badge.img+5
I'd like my regex to replace the middle underscores with a space. I cannot seem to escape the underscore character to use with curly brackets for repetitions.
I have strings with multiple underscores and spaces as word separators. I'd like my result to look like below:
word1_worda wordb wordc wordd_word3
Sample strings look like:
sample1: Autobooster 1_Autobooster Unit_Unit_Autobooster Unit
sample2:Anchor_FIELD_VERIFIED_DATE_NonDisplay
With my format these samples should result to:
sample1: Autobooster 1_Autobooster Unit Unit_Autobooster Unit
sample2:Anchor_FIELD VERIFIED DATE_NonDisplay
I used Lookahead and lookbehind and what I'm getting is the middle string with the underscores between word 1 and word 2 and word 2 and word 3 before and after the result. Regex below
\\w(?<=_).*_?\\w(?<=_)
Test string looks like below
If I were to finish my translation I have to use StringReplacer, StringConcatenator, and then merge them back again.
Best answer by courtney_m
I was able to do this with 2 StringSearchers and an AttributeManager:
The first StringSearcher finds the first word and underscore by searching the text for the Regex ^[^_]*_ and saving it as _first_word:
The second string searched finds the last word and underscore by searching the text for the RegEx _[^_]*$ and saving it as _last_word:
Then, in the attribute manager, I created the _middle_text attribute by trimming _first_word off the left of the text, trimming _last_work off the right of the text, then replacing _ with a space. I used the following notation:
@ReplaceString(@TrimRight(@TrimLeft(@Value(text_line_data),@Value(_first_word)),@Value(_last_word)),"_"," ")
Then, I created the final_text attribute by concatenating the attributes _first_word, _middle_text, and _last_word. Finally, I removed the un-needed attributes.
From inspector, you can see what the value of final_text is....
I have also attached the workspace, if you want it. I hope this helps!
-Courtney
Forum|alt.badge.img+31
  • August 18, 2017
So you want all but the first and last underscores replaced with spaces?
salvaleonrp
Forum|alt.badge.img+15
  • August 18, 2017
Yes, that's the ideal.
courtney_m
  • August 18, 2017
-Courtney
salvaleonrp
  • August 18, 2017
-Courtney
Thanks @courtney_m for explaining and providing your workspace. I appreciate that.
danilo_fme
Forum|alt.badge.img+41
  • August 18, 2017
-Courtney
That is a powerful article. Great! @courtney_m
courtney_m
  • August 18, 2017
Thank you, @danilo_inovacao!
courtney_m
  • August 18, 2017
You're very welcome, @salvaleonrp. I'm glad I could help.
salvaleonrp
  • August 18, 2017
The accepted answer is good enough but I wonder if there's a single regex string to remove the extra underscores. Any takers?
Forum|alt.badge.img+21
  • August 19, 2017
@salvaleonrp, accept your challenge: "single regex string to remove the extra underscores"
[2017-08-20: Update] Simplified the regex.
Use a StringReplacer with these parameters.
  • Mode: Replace Regular Expression
  • Text To Replace: (?<=_)(.*?)_(?=.*_)
  • Replacement Text: \1<space>
This string expression set to a transformer parameter works as well. Assume a feature attribute called "text" contains the source text string.
@ReplaceRegEx(@Value(text),(?<=_)(.*?)_(?=.*_),\1 )
Another thought:
1. StringSearther: Split the source text into 3 parts.
  • Contains Regular Expression: ^(.*?_)(.*_.*)(_.*)$
  • Subexpression Matches List Name: _sub
2. StringReplacer: Replace every underscore in the middle part with space.
  • Attributes: _sub{1}.part
  • Mode: Replace Text
  • Text To Replace: _
  • Replacement Text: <space>
3. StringConcatenator etc.: Simply concatenate the three elements of "_sub{}.part" list.
@Value(_sub{0}.part)@Value(_sub{1}.part)@Value(_sub{2}.part)
The replacement and concatenation can also be performed with a single string expression.
@Value(_sub{0}.part)@ReplaceString(@Value(_sub{1}.part),_," ")@Value(_sub{2}.part)
salvaleonrp
  • August 21, 2017
Another thought:
Awesome!  Learned something new today and valuable in the future. I used AttributeManager and the ReplaceRegex for a new attribute. Thanks @takashi. I have a better understanding of look ahead and look behind now.
