xml via url
I have an issue executing my workbench (It use to work before).
I have a list of url (returning OSM XML files) which I read with a FeatureReader tranformer.
I set the proxy parameters of my orgnization correctly (FME options), and it seems to work fine, until the execution fails (and never at the same stage), see the log below :
XML Parser error: 'Error in input dataset:'http://api.openstreetmap.org/api/0.6/map?bbox=7.1459,43.6763,7.159,43.6858' line:1 column:1 message:invalid document structure'
The XML Module halted on error, see the logfile for details
The XML reader has encountered an error.
The url is valid when I test it... Does anyone have any ideas to solve this problem ?
Thanks in advance,
Fabien
danilo_fme
Forum|alt.badge.img+41
  • April 19, 2018
Hi @flaganne
Try to use the transformer FeatureReader to connect in url, but use the format to Read OpenStreetMap (OSM) XML:
And in Parameters you choose the elements / layers.
Thanks,
Danilo
  • April 19, 2018
this is what I do...
danilo_fme
  • April 19, 2018
OK. What is your FME version?
Check the parameters in configuration Parameters ( icon red ) in your image.
Forum|alt.badge.img+21
  • April 22, 2018
Hi @flaganne, probably the commas within the parameter value have to be encoded with URL (percent) encoding rules, if you will download and read the OSM data directly with a FeatureReader (OSM reader). You can use the TextEncoder (Encoding Type: URL (Percent Encoding)) to encode the parameter value and then build the full URL including the parameter.
http://api.openstreetmap.org/api/0.6/map?bbox=7.1459%2C43.6763%2C7.159%2C43.6858
Alternatively, you can  use the HTTPCaller to download and save a dataset into a temporary location and then read it with the FeatureReader. I think this way is easier and also more flexible.
  • April 23, 2018
Hi  @takashi,
Thank you for your expertise. It did work building the url with "%2C" instead of comas and using the url directly as reader in the FeatureReader.
Thanks,
Fabien Laganne
