How to extract in a shape the largest polygon each time an attribute changes value ?
Exemple
nom surface
2 15
2 20
4 60
4 30
6 15
6 30
6 20
Result
Nom surface
2 20
4 60
6 30
danilo_fme
Forum|alt.badge.img+41
  • January 19, 2018
Hi @pedro
You can use the transformer StatisticCalculator to extract the max value:
Thanks,
Danilo
danilo_fme
  • January 19, 2018
danilo_fme wrote:
Hi @pedro
Thanks,
Danilo
Option Group By = Nom
Forum|alt.badge.img+21
  • January 20, 2018
Hi @pedro, alternatively, if the attribute 'surface' stores the area of the polygon, you can sort the features by 'surface' descending with the Sorter and then sample the first feature for each 'nom' group with the Sampler (Group By: nom, Sampling Rate (N): 1, Sampliing Type: First N Features). The DuplicateFilter (Key Attributes: nom) can also be used instead of the Sampler.
