Hi there. First time user here so apologies if this question has been asked and answered already. I can't seem to find an answer though. I have a .dwg file that has had no set coordinate reference system and when I try to display it in QGIS it appears somewhere over the Antarctic. Is there a way to transform this file into shapefile format and assign a coordinate reference system to it so that it displays correctly? Thank you.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
