Is there a way to remove an existing Workspace Parameter from the FME Server Job Submitter?
Best answer by asmith
So it appears the job submitters carry over all of the parameters of the published child job. Once I removed the parameters from the child job and published it, the parent job submitter parameters updated. Pretty slick, Safe Soft.
