I need to check a match between two output fields. The order of the data is inconsistent, and therefore ABC is not flagging as a match with CBA. I want to alphabetize the text strings so that the order is consistent and can be picked up via the equals or contains function in TestFilter.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
