Using the CKANConnector to Create Resource on OpenGov, works great the issue I'm having is how do you reorder the resources ( or place the new resource at the top of the ordering) by default the sequence number is Max + 1 placing the new resource at the bottom of the listing. In this case we have a few hundred Resources under that one dataset.
