Hello all,
I've got a spreadsheet with filenames, and have been asked to rename the files in a folder/subfolders - with the filenames in the spreadsheet.
After joining them, which works fine, I then put it through an Attribute Manager to have the attached image as an output destination (Folders and a Document at the end).
I was wondering if anyone could shed any light on why the output files, from the FileCopy writer (both Copy and Move mode) come out as folders, and not the PDF files as they went in?
