Find nearest value in a table and join attributes of that row
reservoirdog
Forum|alt.badge.img+10
I have several lines (streets) with a condition-value.
In an (excel) table, I have many rows with condition-values and other attributes I would like to join. Now, coming from my streets I need to find the "nearest" value in the excel-table and join its attributes.
What would be the simplest way to do that?
I have seen an approach of calculating "distances" to each value and then sort by lowest distance... Any other convenient way?
thx for your ideas, best regards from switzerland.
muzhnasto
Forum|alt.badge.img+12
  • September 8, 2021
Hi, maybe if you provide sample data then increase the chance of an answer to your question.
JennaKAtSafe
Hi @reservoirdog​, you might find this article on finding nearest features helpful! https://community.safe.com/s/article/find-nearest-features
reservoirdog
  • September 28, 2021
Thanks @jennaatsafe​ , but I need an approach for searching values (nearest value) than the spatial approach.
The source of the problem is finding the correct value of a normal distribution.
I never found a solution to work directly with mathematical functions, so we divided the normal distribution
in increments. Each increment represents a row in an excel table and I want to find the "nearest value/row" coming from my feature.
normal distribution:
normaldistributionincrements in a table:
increments
