Sort the Matched Output
  • November 5, 2014
  • 13 views
I have a question about the Matcher output and selecting the desired record to move forward.
Here is the scenario:
Matcher_Matched produces some rows.  Matcher_SingleMatched is populated, but that set is sub-optimal (e.g., an attribute is null compared to that within the other matched row).  I need a way to tailor the single-matched rows so they contain the most valuable rows based on a comparison of the matched rows based on attribute comparison criteria.
So, what is the simplest way to loop through the Matcher_Matched result set in order to pick the desired row from those with the same match_id?
Thanks,
Pete
Forum|alt.badge.img+19
  • November 6, 2014
Hi Pete,
Is this simplest?
Sort the Matched features by the criteria, and then pick first features for each match_id group using the DuplicateRemover.
Takashi
gio
Forum|alt.badge.img+15
  • November 6, 2014
Create a tester with the desired comparison on the "Matched" output.
Or create the comparison and then group the match_id's using a listbuilder on match_id and and select the desired ones.
Or create comprison-attribute, sort and pick first one (if ordering is numberbased). If result is some string and sorting/ordering will not resolve the pick, u need to do some test to select.
  • November 6, 2014
Hi and thanks for the suggestions.  I'll try those and see how they work.
