ZIP file name FMESERVER download
  • October 14, 2014
  • 10 views
tono
Forum|alt.badge.img+11
Is it possible to customize the name of the ZIP file to download from FME Server?
I am getting something like this:
http://XXXXXXXXXXX/fmedatadownload/results/FME_57541719_1413289515476_6496.zip
and would like to receive a name from a parameter and a date.
example: http://XXXXXXXXXXX/fmedatadownload/results/database1_10102014.zip
I am working on a FME Server 2014 - Build 14235 - 32 bit win, same FME Desktop version, 32-bit.
Thanks in advance!
  • October 14, 2014
It's in the FME Server Engine configuration documentation:
http://docs.safe.com/fme/html/FME_Server_Documentation/Default.htm#Engines/config_file_layout.htm%3FTocPath%3DFME%20Server%20Reference%20Manual%7CFME%20Server%20Engines%7CFME%20Server%20Configuration%20Files%7C_____1
In particular, look at the AUTO_FILE_PREFIX setting, which defaults to "FME_"
David
tono
  • October 15, 2014
Have not tryed yet, but the documents seem very clear. I Appreciate your help David!
