Failed writing received data to disk/application
fmeuser_gc
Forum|alt.badge.img+8
I get this error when using HTTPCaller for generating .CSV file. It is fully authenticated as the call goes through and has status code of 200.
HTTPCaller_2(HTTPFactory): HTTP transfer summary - status code: 200, download size: '6950 bytes'
ERROR |HTTPCaller_3(HTTPFactory): HTTP/FTP transfer error: 'Failed writing received data to disk/application'
2018-07-16 14:29:06| 1.2| 0.0|ERROR |HTTPCaller_3(HTTPFactory): Please ensure that your network connection is properly set up
2018-07-16 14:29:06| 1.2| 0.0|ERROR |HTTPCaller_3(HTTPFactory): No proxy settings have been entered. If you require a proxy to access external URLs, please ensure the appropriate information has been entered.
Please advise. Thank You
@takashi, @david_r
danilo_fme
Forum|alt.badge.img+42
  • July 18, 2018
Hi @fmeuser_gc
Could you send us your link to make test?
Thanks,
Danilo
laurawatsafe
Forum|alt.badge.img+11
This same issue was raised via support recently, so I thought I'd post a potential workaround for this here (below this explanation):
The error was happening due to a malformed response coming back from the endpoint being accessed in the HTTPCaller. The response included the following header:
  • Content-Encoding: UTF-8
This wasn't really a proper use of this header, as it should be used to indicate any compression used in the response. The character set is given in the Content-Type header:
  • Content-Type: application/json; charset=UTF-8
So this issue was actually a problem with the server that was sending the response.
Workaround
In the HTTPCaller, add a custom header “Accept-Encoding” with no value. This will turn off the automatic decoding of the response.
