Identify maximum value by group and tag feature
aron
Forum|alt.badge.img+16
I have a set of grouped features and want to identify the feature with the highest value in one of the columns, lets call it "MAX_attribute", for each group. I can find the highest value in each group by using the StatisticCalculator. But that only gives me the "MAX_attribute" for the group as an whole, I also need to identify and "tag" the actual feature that had the "MAX_attribute".
To give you an example: I have depth readings for a number of lakes, and now I want to find the deapest reading for each lake.
I also tried the Aggregator with the ListRangeExtractor but could not make it work as I wished.
Best answer by ebygomm
If this is from your earlier scenario, you can create a list in the dissolver. Sorting this list in descending order will mean you can access the feature with the highest attribute
Forum|alt.badge.img+21
  • August 22, 2018
Hi @aron, I think the features output from the Complete port of the StatisticsCalculater have you desired attributes.
Forum|alt.badge.img+31
  • August 22, 2018
aron
  • August 24, 2018
Thanks! I got this to work for me!
