ArcObjects Error -2147467259 Whitespace is not allowed at this location
djmcdermott
Hi FME'ers,
I am currently trying to write OS Mastermap (gml) to an Esri Geodatabase (File Geodb ArcObjects). I get so far before it through's up the error "ArcObjects Error -2147467259 Whitespace is not allowed at this location.
The problem is the log file doesn't tell me where the offending whitespace is...So I look through the erroneous record to try find it but I can't see (by eye) what the problem is.
Is this an ESRI issue or an FME issue?
Thanks,
David McDermott
Best answer by mark2atsafe
Actually I see no record of this message anywhere in our internal systems - meaning no one has reported it before. So probably best to create a support case and submit your workspace and source data to them. With that we might be able to recreate the error and figure out if it is an FME or Esri issue. Does the process work with different Mastermap files? I wonder if it's something in the source data that's an issue (maybe malformed XML)?
mark2atsafe
Forum|alt.badge.img+43
Which Arc version is it? 10? 10.1?
mark2atsafe
  • July 10, 2017
djmcdermott
  • July 12, 2017
Version 10.1
djmcdermott
  • July 12, 2017
I will download a fresh cut of mastermap and try again. If I get the same error I'll log a call, if not it was probably the gml itself.
