How to keep whitespace in strings un-escaped?
  • August 23, 2013
  • 11 views
I'm trying to add an attribute with a constant string value using AttributeCreator, and then have that value output through an XML Writer.  I'm using FME 2011.  The value of the string is "SMALL MAP GRID".  In versions of FME previous to 2011 I used to type the value in that way, inside double quotes.  It came out correctly in the XML output.  Now in 2011, it's putting <quote>SMALL<space>MAP<space>GRID<quote> in the output XML (and of course in the XML the brackets are escaped as &gt and &lt).  Is there a way to keep it from escaping characters like that?  I just want the value to show literally like I typed it.
Best answer by fmelizard
If possible I suggest you upgrade to FME 2013.
There have been many additions and improvements since 2011 for  XML .
fmelizard
Forum|alt.badge.img+17
  • August 24, 2013
