Elastic Reader Issues
bubblebeb
I am having issues connecting to one of our elastic databases. The error I am getting is
Failed to obtain any schemas from reader 'ELASTICSEARCH' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading.
Any ideas what how to fix.
Best answer by jakemolnar
What is the version of your Elasticsearch server? FME currently only supports versions 6.8 and lower. You can check this by visiting your server root page in a browser (example: http://my.server.name:9200/).
Here's a link to the idea for supporting v7+: https://knowledge.safe.com/content/idea/101746/add-support-for-elasticsearch-v7.html
Otherwise, what version of FME are you using? Is it the beta stream perhaps?
jakemolnar
  • July 16, 2020
bubblebeb
  • July 16, 2020
It looks to be Version 7.8 of Elastic.
Do you know when the reader is going to read newer versions?
jakemolnar
It just so happens that I'm working on it right now, as we speak.
It's not my role to make any promises about the schedule, but it would be reasonable to expect support in a Beta release in the near future.
bubblebeb
  • July 17, 2020
@jakemolnar can you let me know when the update is released on the stable version? Many thanks
Seb
jakemolnar
Seb
@sebkingsley I'll ask our Community team to update you, and you can always check the status of https://knowledge.safe.com/content/idea/101746/add-support-for-elasticsearch-v7.html , since they will update it when I complete the new feature.
  • October 27, 2020
Hi, do you have any updates on this issue?
I've seen in the change log of fme desktop 2021 beta (Build 21214) that elastic 7+ is supported. So i've dowloaded it and tried to connect to an elasticsearch 7.9.1, but it doesn't work. Do you have any information of when it will be fixed and if it will work for all 7+ versions (7.9.1 included) ?
jakemolnar
@miay did you add a new Elasticsearch Reader?
In the beta there should be a old Elasticsearch Reader (deprecated, supports versions 6.8 and lower) and a new Elasticsearch Reader (supports version 7+).
If it doesn't work, then we would definitely want to know. Do you have any logs or workspaces you can share?
bubblebeb
  • October 27, 2020
@miay​ I had the same issue and logged a support case for it.
I was hoping the new reader might come in 2020.2
  • October 27, 2020
Yes, i used the new Elasticsearch reader. We use Elasticsearch 7.9. 1. I can create a workspace and send you the logs.
jakemolnar
@miay​  Sounds great, that would be very helpful. Any information about your server configuration would also be helpful (eg. Do you have authentication set up? Are you accessing through a proxy? Do you host the server yourself, or is it on AWS for example? etc. etc.)
  • October 28, 2020
We host the elastic stack.
The fme desktop 2020 beta is installed in a virtual pc within our network.
I can access elastic/kibana from chrome without problems.
I get this error message when i click on the button at the right of "Feature types to read":
The text that appears in the log is: Creating reader for format: Elastic Elasticsearch
Trying to find a DYNAMIC plugin for reader named `ELASTICSEARCH_CLUSTER'
Loaded module 'ELASTICSEARCH_CLUSTER' from file 'C:\\Program Files\\FME2021\\plugins/gdal/GDAL.dll'
FME API version of module 'ELASTICSEARCH_CLUSTER' matches current internal version (3.8 20200922)
jakemolnar
@miay​ is that the entire log?
  • If not, can you attach the entire thing?
  • If so, are there any lines that were red in color? If this is the entire log, then it indicates there may a problem with the configuration of the new Elasticsearch plugin in the beta; unlicensed, missing binaries, something like that.
  • October 29, 2020
Hi, thanks for your answer.
Sorry, i might missed out to explain that i experience the problem when i set up the Elastic reader or featurereader, and click on the button at the right of "features type to read". The reader cannot access the indices in Elastic. So i actually don't have anything to run, and therefore no contents in the log.
Regarding the licensing, i've connected to our license server.
Regarding proxy, we don't need to go through a proxy.
bubblebeb
  • October 29, 2020
This was the exact same issue I had.
The log file stated it couldnt read / find it
jakemolnar
Interesting.. @miay​ and @bubblebeb​, you both also tried the old Elasticsearch reader, right?
Anyway, in a web browser could you go to:
  • [your-elasticsearch-server]/[an-index-you-expected-to-find]/_settings
  • [your-elasticsearch-server]/_cluster/settings
and copy all non-secret results here?
Then I can try to replicate your setup, see what is different with our local testing setup, and account for the differences.
bubblebeb
  • October 29, 2020
Hi @jakemolnar​
{"focalpoint.projects":{"settings":{"index":{"creation_date":"1588326007516","number_of_shards":"1","number_of_replicas":"1","uuid":"PQijcry5SJSccvWyXHjw-A","version":{"created":"7060299","upgraded":"7090099"},"provided_name":"focalpoint.projects"}}}}
{"persistent":{"xpack":{"monitoring":{"collection":{"enabled":"true"}}}},"transient":{}}
"name" : "bad-7-node1",
"cluster_name" : "fg-bad-7",
"cluster_uuid" : "RH6Cl87uQQyYl_q2a7SKwQ",
"version" : {
"number" : "7.9.0",
"build_flavor" : "default",
"build_type" : "rpm",
"build_hash" : "a479a2a7fce0389512d6a9361301708b92dff667",
"build_date" : "2020-08-11T21:36:48.204330Z",
"build_snapshot" : false,
"lucene_version" : "8.6.0",
"minimum_wire_compatibility_version" : "6.8.0",
"minimum_index_compatibility_version" : "6.0.0-beta1"
"tagline" : "You Know, for Search"
Hope that helps.
jakemolnar
Thanks @bubblebeb​, that will be really helpful for me. I'll be able to replicate your setup and see what's going wrong.
  • October 30, 2020
Hi @jakemolnar​ ,
Here are my results:
{"logstash-sodgeopuat-202009":{"settings":{"index":{"lifecycle":{"name":"mmogc-test-ilm-policy"},"refresh_interval":"5s","number_of_shards":"2","provided_name":"logstash-sodgeopuat-202009","creation_date":"1598933246996","priority":"100","number_of_replicas":"0","uuid":"nnhWBroQQzOpySGSYpDSrQ","version":{"created":"7090099","upgraded":"7090199"}}}}}
{"persistent":{},"transient":{}}
 "name" : "myservername",
 "cluster_name" : "elasticsearch",
 "cluster_uuid" : "lymWD6HIS-OLaB2VRiuWIw",
 "version" : {
  "number" : "7.9.1",
  "build_hash" : "083627f112ba94dffc1232e8b42b73492789ef91",
  "build_date" : "2020-09-01T21:22:21.964974Z",
  "lucene_version" : "8.6.2",
jakemolnar
Thanks @miay​, I think I've probably found the problem with your help (and that of @bubblebeb​).
Just to follow up on some probable lines of inquiry: are your Elasticsearch deployments username/password protected?
  • November 3, 2020
Hi @jakemolnar​ ,
Thanks for your efforts!
Yes, our Elastic deployments are password protected.
bubblebeb
  • November 3, 2020
Hi @jakemolnar​
Yes ours are Username and Password protected.
jakemolnar
@miay​ and @bubblebeb​ that's great; that lines up with the evidence I've observed on my end. That means I've likely fixed the issue that was giving you trouble, and I imagine the fix will make it into a beta soon. You can keep an eye out for a change that mentions Elasticsearch in https://downloads.safe.com/fme/beta/whatsnew_2021_0.txt
  • November 3, 2020
Thanks @jakemolnar​ !
I'll keep an eye on "what's new".
bubblebeb
  • November 5, 2020
Hi @jakemolnar​
I have installed Build b21221 and tried to connect to both our elastic stacks (AWS and internal) and get the same error message as before.
ELASTICSEARCH_CLUSTER reader: Failed to open the dataset 'ES:'. Please ensure source data is valid and correct reader is selected
UniversalReader -- readSchema resulted in 0 schema features being returned
Reader Parameter(0) = >https://xxxxxxx.eu-west-2.aws.cloud.es.io:9243/<
Reader Parameter(1) = >USE_AUTHENTICATION<
Reader Parameter(1) = >YES<
Reader Parameter(3) = >BASIC_AUTH_USERNAME<
Reader Parameter(3) = >gis<
Reader Parameter(5) = >BASIC_AUTH_PASSWORD<
Reader Parameter(5) = >********<
Reader Parameter(7) = >RETRIEVE_ALL_TABLE_NAMES<
Reader Parameter(7) = >YES<
Reader Directive(0) = >USE_AUTHENTICATION<
Reader Directive(1) = >YES<
Reader Directive(2) = >BASIC_AUTH_USERNAME<
Reader Directive(3) = >xxxxxxx<
Reader Directive(4) = >BASIC_AUTH_PASSWORD<
Reader Directive(5) = >********<
Reader Directive(6) = >RETRIEVE_ALL_TABLE_NAMES<
Reader Directive(7) = >YES<
ELASTICSEARCH_CLUSTER reader: A fatal error has occurred. Check the logfile above for details
Any tips on what might be the cause of this?
Thanks
Seb
jakemolnar
@bubblebeb​ that's strange; our QA department verified that we are able to connect to an AWS-hosted and password-protected cluster now.
I've seen this kind of error when the cluster is completely empty; do you have any indices created?
Have you made sure the deployment is reachable from your machine? ie. trying to reach https://xxxxxxx.eu-west-2.aws.cloud.es.io:9243/
in a browser or with curl like `curl --user 'username:password' -XGET https://xxxxxxx.eu-west-2.aws.cloud.es.io:9243/`
