Create multiple points from one based on an three id fields.
Hello everyone,
I am trying separate point features from one single point to two, three, or four overlapping points based on ids in four fields. This is a reverse of a process I created earlier to get the points from separate points into one point with the IDs.
It would look like this:
Starting feature: ID1, ID2, ID3, ID4
becomes four stacked points
Result feature 1: ID1
Result feature 2: ID2
Result feature 3: ID3
Result feature 4: ID4
I suspect I would put these IDs in a list and then write out features based on the list. I just can't quite sort out how to accomplish this in FME.
Thanks
  • July 19, 2013
Hi Justin,
The ListExpressionPopulator creates a list of attributes having a common expression in their names.
For example, the transformer with the following settings creates a list named _id{} containing every attribute whose name starts with "ID":  Source Attribute Expression: ^ID List Name: _id Then you can transform an input point into stacked multiple points using a ListExploder. If some _id might be empty, filter out them by a Tester.
Alternatively, using parallely four AttributeRenamers against one original feature would also work. Each AttributeRenamer renames IDn (n is one of 1, 2, 3 or 4) into _id. This looks not elegant, but is maybe more efficient because this doesn't create any new attributes at all.
Takashi
  • July 19, 2013
Hi T
hank you Takashi. In between submitting my question and your reply I figured out good solution. It's one of those times where I just needed some energy from others and just had to go ahead and ask the question.
I use ArcGIS less and less and FME more and more. I basically did what I would do in any other software (arc) manually and did it easy in FME.
I used ATTRIBUTE FILTER AND ATTRIBUTE COPIER. Once again I was complicating something very simple. This was a matter of filtering the fields that contained values and copying those values to a single id field. FME does this very nicely. New features are automatically created. The thought of doing this same process in Arc just seems--well--stupid.
Thanks again Takashi
If anyone stumbles upon this looking to do the same thing, I'd be happy to explain.
Thank You.
If someone ever stumbles upon this I will be happy to explain.
  • July 19, 2013
Hi Justin,
Glad to know you found a good solution.   > a matter of filtering the fields that contained values and copying those values to a single id field   For such a case, applying the "Conditional Mapping" functionality of the AttributeCreator (FME 2013 SP1 or later) could be a more compact solution.
In many cases, there are several approaches with FME to do the same thing, so it's interesting ;-)
Takashi
