Failed to add CSV to ESRI ArcGIS Portal in one process
  • October 20, 2024
  • 0 replies
  • 18 views
fei2000
I am new to FME Workbench and I am using the latest 2024.1 version.
When I tested to add CSV to ESRI ArcGIS Portal as a new point feature layer, it succeeded to create a new feature service in portal but failed to insert CSV data into the newly created feature service with following error message: “ArcGIS Portal Feature Service Writer: UPSERT failed for feature service 'Sample_Test': Append job failure: 'Operation rolled back.'”
Then I have to re-run my workbench again, and this time it will insert all CSV data into the portal feature service without any issue.
BTW, I am using “Create If Needed” as Feature Service Handling parameter.
Could someone help me out to make this workbench adding CSV data to ArcGIS Portal in one process? Thanks.
Be the first to reply!
