I’m trying to read this wfs-service https://avoin.metsakeskus.fi/rajapinnat/v1/gridcell/wfs or alternatively https://avoin.metsakeskus.fi/rajapinnat/v1/gridcell/ows with FeatureReader and FME returns following error:
2024-09-11 10:32:43| 0.0| 0.0|ERROR |<ows:ExceptionReport xmlns:xs="http://www.w3.org/2001/XMLSchema=" xmlns:ows="http://www.opengis.net/ows=" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance=" version="1.0.0=" xsi:schemaLocation="http://www.opengis.net/ows https://avoin.metsakeskus.fi/rajapinnat/schemas/ows/1.0.0/owsExceptionReport.xsd=">
<ows:Exception exceptionCode="InvalidParameterValue=" locator="namespace=">
<ows:ExceptionText>Unknown namespace [v1]</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
2024-09-11 10:32:43| 0.0| 0.0|ERROR |Received error report: ExceptionReport
2024-09-11 10:32:43| 0.0| 0.0|ERROR |The XML Module halted on error, see the logfile for details
2024-09-11 10:32:43| 0.0| 0.0|ERROR |A fatal error has occurred. Check the logfile above for details
2024-09-11 10:32:43| 0.0| 0.0|ERROR |<WFS> An error occurred while reading a GetFeature response, to ignore the error and avoid losing the previously read features, set the WFS "Ignore GetFeature Error" parameter. Total features downloaded: '0'
2024-09-11 10:32:43| 0.0| 0.0|FATAL |The below feature caused the translation to be terminated
2024-09-11 10:32:43| 0.0| 0.0|ERROR |FeatureReader_<Rejected> (TeeFactory): FeatureReader_<Rejected>: Termination Message: 'FeatureReader output a <Rejected> feature. To continue translation when features are rejected, change 'Workspace Parameters' > Translation > 'Rejected Feature Handling' to 'Continue Translation''
2024-09-11 10:32:43| 0.0| 0.0|ERROR |FeatureReader (QueryFactory): Termination Message: '%0'
2024-09-11 10:32:43| 0.0| 0.0|ERROR |Q5314A_karttalehti_SHAPEFILE_2_-1_30_Player (RecorderFactory): FeatureReader_<Rejected>: Termination Message: 'FeatureReader output a <Rejected> feature. To continue translation when features are rejected, change 'Workspace Parameters' > Translation > 'Rejected Feature Handling' to 'Continue Translation''
I have turned ignore applications schema on but I still get the same error. Is the problem on the server side and is there any possibility to read this with FME? Service seems to be working fine with QGIS. I’m using FME Desktop 2021.2.
