I have a problem. I just created a line out of multiple points of an x,y,z text file with the LineBuilder tool. The problem is that the points name are lost. After the LineBuilder I use a Chopper to split the line into segments. Now I want to add a new attribute to the line segments, which has the initial names of the points. Because due to the LineBuilder the names are lost and are everywhere the same. How can I do that?
