Geodesic Geometry Writer
  • September 1, 2015
  • 8 views
Hi all,
Is there a possibilty to write geodesic Data to an AIXM Writer? Now I use the GeometryPropertySetter Transformer, but it creates a LinearRing instead of a GeodesicString. I found an entry in the fme wiki about geometry builders:
xml-geodesic-string (http://docs.safe.com/fme/2013/html/FME_ReadersWriters/Default.htm#xml/xml_geodesic_string.htm): is non-composite builder that interpolates a sequence of geodesic control points into a line geometry. (Built-In Geometry Builder (http://docs.safe.com/fme/html/FME_ReadersWriters/FME_Readers_Writers.htm#xml/built_in_geometry_builde.htm%3FTocPath%3DFME%2520Readers%2520and%2520Writers%7CXML%2520%28Extensible%2520Markup%2520Language%29%2520Reader%252FWriter%7CxfMap%7CFeature%2520Mapping%2520Rules%7CBuilt-in%2520Geometry%2520Builders%7C_____0" target="_blank))
But I don't get how to activate the geodesic geometry builder.
Thanks,
Mel
Best answer by me1
Sorry about the links, somehow the link function didn't work out.
  • September 1, 2015
