Using LIKE or Wildcardoperator in Feature Merger
  • December 8, 2017
  • 194 views
I have to merge two tables with the common field.. one is from plain sql database and other is feature class..
Here I am using Feature Merger transformer..But I have to query the data in feature class using wild card search (data) from table1.
SQLDatabase-------------------(Select Code from Table1)
FeatureMerger ----> I want to query the data FCField like Code
FeatureClass -----------------(Select FCField from Featureclass)
Any help would be highly appreciated.
Cheers,
Srikanth Dasari
Forum|alt.badge.img+21
  • December 8, 2017
Unfortunately the FeatureMerger doesn't support LIKE operation.
If the feature class was a table in the same database, what SQL statement would perform ideal table joining? Possibly a solution might be found depending on the WHERE clause in the SQL statement.
  • December 8, 2017
Hi @kanthsri74,
Have you checked the InlineQuerier? It is a powerful alternative for the FeatureMerger and it supports LIKE statements.
https://www.safe.com/transformers/inline-querier/
