I am using the SpatialRelator for populating a list of adjacent polygons for specific polygons of a geojson polygon layer. I tried the "Requestor Intersects Supplier" and "Requestor Touches Supplier" predicates but they also include those polygons touching at only one point. I only want those sharing a line, so I have a ListElementFilter taking only the following relationship masks: FF2F11212 and FF2F1F212. The problem is that the process is much slower when adding that custom transformer. It is even worse when I use the "FF2F11212 FF2F1F212" value in an attribute in the "spatial predicates to test" field. Can you think of a more performant way to obtain the adjacent polygons into a list?
Thanks!
Olivier
