FME 2020: How to filter dwg file based on hatches and Areas (polylines)?
I couldn’t figure out how to filter dwg file based on hatches and Areas (polylines).
Best answer by jkr_wrk
You can expose all kinds of autocad attributes. If you click on the feature you will see all attributes in the feature information window.
Like: autocad_entity_handle, autocad_frozen and autocad_entity
I guess the autocad_entity contains the type of autocad feature.
The geometry filter tells what kind of geometry it is: single point, multipoint, lines, closed lines etc.
