Hello, I have a workspace with a Reader DWG. In the DWG, we use blocks with custom rotation. the reader does not keep the name and the rotation of the block. The outpul file doesn't contains this blocks. Can you help me? Best Regard Bernard Di
bernarddinon
This some détails.
Our Bloc "Orientage Crosse" has an custom orientation (Print Screen 1)
Print Screen 1
RESA_BLOC_Orientage Crosse
The dwg source has some block "Orientage Crosse" with a rotation and Angle1 (Print Screen 2 to Print Screen 6).
In FME with the readers, the name of the block it's not "Orientage Crosse" but a specifi name like *U365, *U400,... (cf Print Screen 7 to Print Screen 10).
The oriention and the Angle1 don't have the expected values.
If my block hasn't angle1 like in print Screen 1, we don't have the problem.
Someone can help me?
Print Screen 2
RESA_BLOC_Orientage Crosse_U395
Print Screen 3RESA_BLOC_Orientage Crosse_U396
Print Screen 4
RESA_BLOC_Orientage Crosse_U398
Print Screen 5
RESA_BLOC_Orientage Crosse_U400
Print Screen 6
RESA_BLOC_Orientage Crosse_U401
Print Screen 7
RESA_BLOC_Orientage Crosse_U395_FME
Print Screen 8
RESA_BLOC_Orientage Crosse_U396_FME
Print Screen 9
RESA_BLOC_Orientage Crosse_U398_FME
Print Screen 10
RESA_BLOC_Orientage Crosse_U400_FME
Best answer by deanhowell
Hello @bernarddinon​ are the blocks attributed or dynamic? We have had a similar issue with the '*Uxx' as FME does not handle the dynamic blocks. We have had to create an attribute on the block in AutoCAD of the block name so we can then read the attribute rather than the name FME gives it.
Are you able to share a sample drawing and I will see what I can do to help further?
deanhowell
Forum|alt.badge.img+23
  • August 4, 2020
bernarddinon
Hello, @deanhowell​
Thank for your answer. The blocks seem dynamic because of Angle1. If i delete this part, the block become attributed.
I make a simple workspace for example (Print Screen 1).
I create a workaround to my example. I use test filter to find blocks *U and replace the autocad_block_name by the good name, but i don't have the orientation and Anlge1
I join my workspace in a fmwt file.
Best Regards
Bernard Dinon
Print Screen 1
RESA_BLOC_Orientage Crosse-Workspace
virtualcitymatt
Forum|alt.badge.img+34
Yes, unfortunately FME doesn't support dynamic blocks properly. Not even the name is read correctly. There is an idea here which you can vote on:
https://community.safe.com/s/idea/0874Q000000TktZQAS/detail
deanhowell
  • August 4, 2020
Thanks @bernarddinon​ nothing yet but I wonder if FME is not interpreted the angles from the drawing as they are in grad. I will keep looking and let you know.
bernarddinon
@deanhowell​
Thank for your help
bernarddinon
@virtualcitymatt​  Thank for your answer. I voted for this idea
bernarddinon
@deanhowell​ @virtualcitymatt​
Hello,
For my problem. We have decide to modify our block. We have delete the angle in the block et we don't have problem.
Thanks for your help
Best Regards
Bernard Dinon
