Has anyone had success using the ProjectWise connector in FME 2018.0.0.2 (64bit)? If so would you be able to share your set up or configuration - or if there were any "gotchas" that you came across.
We are using ProjectWise which allows me to access it through a browser via https://projectwiseweb.lendlease.com
This succesfully brings up a page whereby you can select a "Location" (of which we have multiple) and type in credentials. Once you are in you can navigate similar to the ProjectWise explorer desktop app.
If I use that URL and credentials in the ProjectWise Connector I get "Failed to Load folder from Bentley ProjectWise"
Would love to hear from anyone who has had success with this connector as it will really open up some great opportunities for us.
Could someone from Safe also have a look into the help documentation for this - there doesn't appear to be any.
Thanks!
