Hello, is it possible to set the cell/column width in a dynamic Excel Writer. I can imagine to precalculate the width for each column or to use a auto mode. Hendrik
Set cell width in dynamic Excel writer
Best answer by helmoet
Hi @hendrik @xiaomengatsafe @gio @krisvesweco , I faced the same problem writing a dynamic feature type on an Excel writer, and this is the solution I came up with:
The warnings do not show up anymore and Excel is generating correct column widths. No post processing needed.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
