Excel Writer warning after moving to 2018 beta
carmijo
Forum|alt.badge.img+11
I'm testing my current workspaces in FME 2018 Beta and i'm getting a new warning from an Excel Writer.
WARN |Excel Writer: Attribute xlsx_row_formatting is empty, no row formatting applied
It doesn't seem like this warning is anything to be concerned about but i'd like to make any changes possible to prevent it from showing up as many times as it does while running. I can't seem to locate the much documentation on the xlsx_row_formatting attribute, so i'm wondering, is there any way to populate it to prevent the warning?
Thanks!
Best answer by debbiatsafe
Hi @carmijo
This issue was reported internally and have been fixed in the FME 2018.0 beta builds 18252 and higher. You will find the update in our latest FME 2018 beta: safe.com/beta
Kind regards,
Debbi
debbiatsafe
Forum|alt.badge.img+20
  • January 30, 2018
Hi @carmijo
Kind regards,
Debbi
carmijo
  • January 31, 2018
Thank you @DebbiAtSafe
