KMLviewssetter: advanced kmlviewsetter balloon formatting.
jhawks
Forum|alt.badge.img+7
I'm starting with background color as a test, since it takes html I thought this would change the balloon BG color but it's not working.
<html> <body bgcolor="#E6E6FA"> <img src="https://seamlessrnc.nauticalcharts.noaa.gov/rnc/noaa_ocs_small_banner.jpg"></a> <BalloonBGColor = '-1' BalloonFGColor = '-16777216' BalloonBGColorField = ''red" > </body> </html>
danilo_fme
Forum|alt.badge.img+44
  • March 29, 2018
Hi @jhawks
Would you like to work with Watermark in KML? Like this Link https://knowledge.safe.com/articles/20209/kml-screenoverlay-watermark.html
Thanks,
Danilo
jhawks
  • March 29, 2018
arc2earth-popup.jpgfme-popup.jpg I've got watermarks working, this is about formatting of kml popup balloons. I'm to recreate as much possible the arc2earth popup balloon in my new kmz created by fme.
danilo_fme
  • March 29, 2018
Did you see this link https://knowledge.safe.com/articles/18754/kml-balloon-contents-removing-directions.html ?
And this Balloon width ?
Thanks,
Danilo
jhawks
  • March 29, 2018
I have looked at both of them but they don't quite have the in depth formatting I want. I was able to add an image, and remove the balloon title, but for example if I want to remove the grey background from every other record how would I do that. Not crucial but if it takes full html formatting there should be a way.
danilo_fme
  • March 29, 2018
Hi @jhawks
OK, could you send me the Workspace template?
Thanks
Danilo
debbiatsafe
Forum|alt.badge.img+20
Hi @jhawks
In the KMLPropertySetter, you can create and customize an HTML table in the Content parameter. I found it easiest to copy an attribute table for a feature from an existing KML document and edit it directly. I believe the <tr bgcolor="#E3E3F3"> is the correct tag to change if you wish to remove the background colour. Remember to change the Content Type to HTML and disable 'Include Attribute Table'.
There may be an easier way to change the row's background colour that I'm not aware of. If someone knows, please feel free to comment.
Hope this helps.
jhawks
  • March 29, 2018
noaa-rncs-shape-kml.fmwt
Sure, see attached.
debbiatsafe
Sure, see attached.
Hi @jhawks
Please see the attached fmwt for a background-less table within the balloon
noaa-rncs-shape-kml-notablebackground.fmwt
I would also suggest looking at the KML Documentation if you wish to format the balloon further https://developers.google.com/kml/documentation/kmlreference#balloonstyle
jhawks
  • April 3, 2018
Thanks! Very helpful. I still have some formatting to do but should be easy now! I kept trying to do full html in content. This should be close enough to get me thru it, thanks again!
