I use a SQL creator on a Oracle Spatial database extracting around 40 columns.
I would want to score the fid of this extraction in order to use it in the where clause of a post-gis reader. This to avoid the post-gis reader to read all 1 000 000 records when I only need 300 of those.
How can I do this ? I did some research but seems I am using the wrong key words as I can't find it.
Thank you
