Retrieve data source from MXD or Lyr
  • December 2, 2015
  • 15 views
Hello,
I use FME to retrieve some metadatas from various formats and I tried to find a way to get the data source of the datasets linked to a MXD or a Lyr with no result. I suppose FME has the information because he can read the linked datasets...
Is there a solution or I have to directly use libraries like arcpy or ArcObject ?
gio
Forum|alt.badge.img+15
  • December 2, 2015
yup, Arcpy would work.
Have not tried it myself in a PythonCaller, or fme startup script though.
Never tried the ArgisMap reader myself, did you?
