The esri shape file reader truncates attribute names to 10 character
Why does the shape file reader truncate the names attributes to 10 characters on loading / inserting the reader? I have fme version (FME(R) 2018.0.0.1 (20180328 - Build 18295 - WIN64)) installed.
  • April 15, 2018
Hi @vandijkjoostjan, in any Esri Shapefile dataset, the length of every attribute name should be equal to or less than 10 bytes. It's a restriction according to the specifications of the format dBASE (DBF) which is adopted as the format of attribute table for the Esri Shapefile.
fmelizard
Forum|alt.badge.img+17
  • April 16, 2018
When you look at it in ArcGIS, do you see longer field names? I"m wondering if the metadata in the attached XML file provides longer name aliases?
Thank you for the information
