Released
Retry job setting on failure of a scheduled job
Related products:FME Form
  • January 18, 2018
  • 4 views
siennaatsafe
lars_de_vries
+7
  • siennaatsafe
    siennaatsafe
  • takashi
  • lars_de_vries
    lars_de_vries
  • hmm
  • jnfung
  • jakob
  • cwarren
    cwarren
  • candacelow
    candacelow
  • jpvo
    jpvo
  • psachin
  • heidirk
  • tmoulder_okc
Add a setting to allow the job to be retried on failure x number of times. We have some jobs that fail due to timeout, and running the job a second time doesn't experience the same timeout issue. It would be nice to set that on the schedule. I am assuming the future automation section of server could be able to address this type of request as well.
Merged Ideas:
Add Retry Times option to Schedules in FME Server by takashi on March 9, 2018
Some kind of scheduled jobs could fail because of an external reason. e.g. a case where an external server which manages resources for the job is busy at the moment when FME Server access the resources.
In order to be able to recover such a failure as soon as possible, it might be useful if the schedule setting would have an option to set the number of retries and their time interval in the case where the job failed.
rylanatsafe
Forum|alt.badge.img+13
  • September 25, 2020
We have made some improvements to FME Server Automations and the 'Run a workspace' action.
If you use Automations to setup your schedule, there is a new "Retry" tab for each workspace action that you can configure! Check out this screenshot from FME Server 2021: https://drive.google.com/file/d/11SsSW-JvzLmfo5m7FA306vJ0pb2lZb4d/view?usp=sharing
If you would like to test this out, you can download the beta today! https://www.safe.com/support/downloads/
