Column to ROW as attribute name for other columns
Good day!
I'd like to change data structure from as shown on 1st
picture to structure as shown on 2nd picture.
Simply stated i want values replace from first column (Attributes) to attribute name values and second column should be values for these attributes. I think Attributes field on 1st picture will not be stable. Elements will change from time to time.
This is a subtotal result from big WB processing result...
I tried to use AttributeCreator, but result is not good(.
How can i do this?
Thanks)
bruceharold
Forum|alt.badge.img+17
  • May 26, 2016
Use AttributeCreator with AttributeName set to @Value(Attribute) and Value set to Value
  • May 26, 2016
It does not work...I tried to do how you said, but nothing changes.
Also, I saved the result as xls file and tried to do this again...nothing.
Forum|alt.badge.img+21
  • May 27, 2016
Hi @sega, I think the AttributeCreator should work, but the new attribute names will not be exposed automatically on the Workbench interface. Check the result with the Logger or the Feature Information pane of FME Data Inspector. You can expose the attribute names manually with the AttributeExposer optionally.
  • May 27, 2016
Hello @takashi, yes, I did like you say. It works)
But what if attributes are not stable? It means...names and counts of attributes are changing. Today I have all attributes shown on this example and tomorrow i will get these attributes and one( two, three...) more (f.e. Vessel Type). If I will use AttributeCreator ---> AttributeExposer with predefined list of exposed attr, I will lose "Vessel Type"...
How to solve this situation "dynamically"?
Thanks!)
  • May 27, 2016
Thanks!)
If the schema (the number of attributes and their names etc.) may be vary, you will have to implement a work flow to create the schema based on the source data at run-time, and also apply the dynamic schema to the writer.
There are several ways and variations to do that, but It's hard to find an appropriate way based on the current limited information.
Firstly you need to learn about the Dynamic Workflow. I think this article would be a good starting point.
Tutorial: Dynamic Workflows
gio
Forum|alt.badge.img+15
  • May 28, 2016
check out suggestions under dynamic attribute creation.
  • May 30, 2016
@takashi, @bruceharold thanks a lot for your suggestions
