Convert to/from FILETIME
sigtill
Forum|alt.badge.img+24
I need to convert to/from FILETIME in FME2016.....
So for instance FILETIME=131443544400651329
http://www.silisoftware.com/tools/date.php?inputdate=131443544400651329&inputformat;=filetime
Will be converted to:
2017-07-12T17:34:00+00:00
Some hints here:
https://stackoverflow.com/questions/19801727/convert-datetime-to-unix-timestamp-and-convert-it-back-in-python
However I am curious if there is a simpler way to do this in FME?
Best answer by david_r
Looks like you could implement it fairly easily in Python as well:
http://reliablybroken.com/b/2009/09/working-with-active-directory-filetime-values-in-python/
Hi @sigtill
So I could kind of do it in FME 2016 by calling the URL from the HTTPCaller. However, you then need to extract the right time format that you're interested in. So I'm not sure if that's simpler than python.
If you could use FME 2017, putting that URL in the HTML Table Reader was nicer.
@LenaAtSafe @taiatsafe I don't know whether either of you have looked at filetime?
  • July 13, 2017
