When Writing to CityGML Format, HREF links to the surfaces (Roof, Wall, Ground) are not generated
  • August 31, 2017
  • 6 views
I am trying to write a CityGML file using FME Desktop 2017. I can write the Roof, Ground and Wall surfaces features which contain the geometries, however, the "Building" featureclass does not contain the HREF links to those surfaces.
This is easy to detect when using the inspector, as the Building featureclass does not show up as spatial.
I have set gml_parent_id in the surface classes, to the value of gml_id used in the building class.
rylanatsafe
Forum|alt.badge.img+13
  • August 31, 2017
This is currently not supported (as of this writing) but there is an internal ticket tracking progress on implementation. I'm sorry for the inconveniences experienced by all who require this ability!
Please show your support by voting for this KC Idea!
