RegEx help needed. Separate one attribute into four attributes
I'm new with FME. I have one attribute with this value "Zonne-energie in woonplaats vermogen 0,2394 MW, beschikte productie per jaar 227,43 MWh, looptijd 15 jaar. Het project is nog niet gerealiseerd (peildatum januari 2020)."
I want 4 values out of this values and put them into 4 attributes.
- 0,2394 MW into VERMOGEN
- 227,43 into PRODUCTIE
- 15 into LOOPTIJD
- januari 2020 into PEILDATUM
I want to use StringSearcher but i don't what Regular Expression to use. C
Who can help me?
Forum|alt.badge.img+31
  • March 5, 2020
It would probably be helpful to provide some additional examples of your attribute values to enable queries to be formulated
erik_jan
Forum|alt.badge.img+17
  • March 5, 2020
I created a workspace for the 4 regular expressions.
Hope it helps.
regex.fmw
  • March 5, 2020
Making lots of assumptions here, but try the following four StringSearcher:
VERMOGEN
vermogen (\d*\,?\d+ \w+)
PRODUCTIE
productie per jaar ([[0-9]*[,]]?[0-9]+)
LOOPTIJD
looptijd (\d+)
PEILDATUM
peildatum (\w+ \d+)
All assume that the StringSearcher has been configured with a subexpression list name e.g. "_subs", the result will then be in "_subs{0}.part"
  • March 5, 2020
But for example:
VERMOGEN
a number followed by MW but not h
[0-9]*,*[0-9]MW(?!h)
PRODUCTIE
a number followed by MWh but only return the number
[0-9]*,*[0-9]*(?=\sMWh)
LOOPTIJD
A numerical value followed by jaar
[0-9]*(?=\sjaar)
PEILDATUM
Some letters and 4 numbers always preceded by peildatum
(?<=peildatum\s)[A-Za-z]+\s[0-9]{4}
  • March 9, 2020
Thank you all. It works!
