We are building a data extraction tool based on FME Server. This application build a form dynamically based on the published parameters. It needs to work in french and in english. Since i18n isn't possible on parameters descriptions and alias, we need to rely on a custom format that we put in the descriptions. The application has an additionnal step of parsing the descriptions to get the french or the english names/descriptions depending on the current language of the user.
Is there any plan to support i18n on parameter names and descriptions?
Is there a different way to manage that then the one we use?
Thanks!
