Want to split an attribute, then make new rows that insert the separated values into the new rows
schulte.a
Forum|alt.badge.img+3
I have a table where I have emergency meeting points. Each building has a meeting point, some buildings have many points, here is an example:
Building Meet_Points
123 11,12,13
124 16
I would like the table to look like this:
123 11
123 12
123 13
124 16
How would I separate those meet points, and make numerous rows of the same building that has each meet point and all the other attributes carry over to the newly made rows and are the same?
Best answer by liamfez
You can use an AttributeSplitter on the meeting points attribute. It will create a list and then you can use the ListExploder to explode that list into multiple features.
liamfez
Forum|alt.badge.img+34
  • May 14, 2024
schulte.a
  • May 15, 2024
Awesome, i’ll give that a shot! Thanks for the help :)
