Use Published Parameters in a FeatureReader for Postgress to get generic output
erikboehm
Forum|alt.badge.img+3
I am using a FeatureReader to read a Postgres db table. As I want the workspace to be easily migrated from developement to production system, I use Published Parameters to supply the connection parameters, meaning I use a parameter committing the name of a FME-DB-Connection and two parameters (Published_Parameter_Schema.Published_Parameter_Table) for the Feature Types to Read. Unfortunately, no output is generated from the generic port (no error message in the transition log), even if I expose the attribute within the FeatureReader or with an AttributeExposer afterwards.
As a workaround, I use a AttributeCreator to commit the Published Parameters for the schema and the table into attributes before using them as input for the FeatureReader. With exposing the attributes from the Postgres-DB inside the Transformer, this works fine.
But I keep wondering, why it doesn't work using Published Parameters directly?
nielsgerrits
Forum|alt.badge.img+54
What version FME do you use? This works perfectly fine in 2019.1 and 2020.2.
Do you have uppercases in you schema and/or table name? Because those are case sensitive.
erikboehm
  • January 20, 2021
Update 21.01.2021:
I upgraded my FME Version to 2020.2, but the problem still exists.
I checked the casing and also tried to change the Published Parameters into lowercase, similar to the attributes I use as a workaround.
Did you also trie to connect to a Postgres/PostGIS-Database?
I use FME 2020.1. So I will upgrade my FME version and see, if that was the problem. Thank you!
