use default value in published parameters on fmeserverjobsubmitter if not set
giosp
I have a core workbench that is called from a fmeserverjobsubmitter with several parameters from the submitter workbench.
Now in the core workbench I added a new parameter. If I don't refresh the fmemserverjobsubmitter in the submitter workbench, the behaviour is what I expected: new runs of the submitter workbench works with the default value set in the new parameter.
If I refresh the fmeserverjobsubmitter the new parameter is present in the list of my parameters. Now I'm forced to set a value in the parameter box. If I leave the value empty, the jobsumbitter send an empty value to the core workbench. I've tried to switch to private parameter and set the default value but I have to maintain the value in the private parameter.
How I can force the core workbench to use the default parameter set in it? I'd like that the behavoiur in this case is the same as the programming language. For example:
def myProcedure(param1, param2 = False):
The param2 is set to false when I call myProcedure(value1) .
The goal is to have the autoset of the value from the defaul parameter set in the core workbench.
Thank you for any suggestions
  • March 29, 2019
I'm not sure that's currently possible, short of what you've already tried.
giosp
  • March 29, 2019
Thank you @david_r,
I think that I will create a optional parameter empty at default and manage the real parameter used in the workbench as a python script type with a control structure...
  • March 29, 2019
giosp wrote:
Thank you @david_r,
Yeah, that's probably the most robust solution. I would've done the same thing myself.
