write ST_geometry to a Postgis database
mapper
Is it possible to write ST_Geometry to Postgis database? I don't see any parameters in the Postgis writer that would allow this, so I am wondering if there is any work around?
erik_jan
Forum|alt.badge.img+17
  • January 28, 2016
As I recall the answer is Yes.
But you have to create the table in PostGis (using the ST_geometry type) and then import the table definitions in FME.
bigclyde
  • November 27, 2019
This is exactly what I need to do (migrating a Geomedia Sql Server Warehouse to an Esri enterprise Postgis geodatabase) but I see the post is a few years old.
Is it still true? Is there any other way?
Thanks
