Which transformers to use to split lat long coordinates to create a new row....
I have a excel file with 3 columns (attributes) and fourth is a coordinates (lat/long) (polygon) which are separated by space and have different amount of numbers after the dot.
Input:
ID, Name, Number, Coordinates
01, First, 1001, 27.94324 34.34834 27.013 34.560 27.43479125 34.96844321
Desirable Output:
01, First, 1001, 27.013 34.560
01, First, 1001, 27.43479125 34.96844321
AttributeSplitter cant do it
How to automate it?
Thanks for help in advance.
  • January 29, 2016
The StringReplacer with this setting inserts commas (or any preferable delimiter) between pairs of lat/lon.
  • Attribute: Coordinates
  • Text to Match: (\\d+(\\.\\d*)?\\s+\\d+(\\.\\d*)?)\\s+
  • Replacement Text: \\1,
  • Use Regular Expressions: yes
You can then use a combination of the AttributeSplitter and ListExploder to get your desired table.
  • January 29, 2016
  • Text to Match: (\d+(\.\d*)?\s+\d+(\.\d*)?)\s+
  • Replacement Text: \1,
Another approach. The PythonCaller with this script may be effective.
class FeatureProcessor(object):
    def input(self,feature):
        coords = feature.getAttribute('Coordinates').split()
        for latlon in zip(coords[0::2], coords[1::2]):
            feature.setAttribute('Coordinates''%s %s' % latlon)
            self.pyoutput(feature)
erik_jan
Forum|alt.badge.img+17
  • January 29, 2016
Another way to do this:
Create a line geometry from the coordinate list. To do that follow the next steps:
1) create a new attribute "geometry" using a concatenation in the text editor:
<gml:LineString srsDimension="2"><gml:posList>
</gml:posList></gml:LineString>
2) Use the GeometryReplacer (encoding GML) to create a line object.
3) Use the Chopper (1 vertex per object) to create multiple point objects
4) If you need attributes use the CoordinateExtractor to get lat. and long. into attributes
That will give you the desired output without any coding.
  • January 29, 2016
This simple regex works in this case.
  • Text to Match: (\\S+\\s+\\S+)\\s+
