I have a logger output excel spreadsheet where the easting, northing, height, and sensor value are in one column but I need them each to be an independent column. So I need to add four new columns to the excel and populate them from the one column while leaving the loggercode and dateutcdate alone.
How to transpose an excel sheet, but only a couple of columns.
Best answer by takashi
Hi @mcgregrr, this screenshot illustrates a possible way. Hope this helps.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
