In my LAS reader I have selected fme_basename to be outputted as an attribute with the feature.
In the data inspector I can see it has correctly populated this attributed with the filename of my LAS.
The dropdown under DEMRaster in the ReasterDemGenerator shows that fme_basename is an attribute.
However when I look in the data inspector it doesn't contain my LAS filename but instead 'RasterDEMGenerator'
Is this correct? I was going to read multiple LAS files and output a DEM for each file, using the fme_basename as the filename for the DEM. Seeing it's not being carried through though I've had to create a user parameter and process one file at a time now.
Thanks in advance.
