After upgrading a Schemamapper transformer from FME 2016 to FME 2018, I get an Connection error from within the Schemamapper (pointing to an Access database) : "Connection does not exist", even though nothing has changed. It is an upgrade problem cause any workflow with that Schemamapper in FME 2016 works without problem The same workflow opened in FME 2018 desktop has a red settings button and the abovementioned error. What to do?
